#8443 points
You are driving a motor vehicle with a manual gearbox on a level carriageway. How should you change gears so as to drive in a particularly environmentally conscious and economical way?
Changing up gears as early as possible
Drive until the upper engine speed range is reached in one gear, before changing up
Changing down again as late as possible
