#8283 points
You are driving a motor vehicle with a manual gearbox. What must you consider when you see this road sign?
Applying the brakes for a longer time will diminish the braking response
The braking response will be better if no gear is engaged
The braking distance is longer
accuracycheck_circle0
correctcancel0
