#7383 points
You have to remove a defective tyre. In what sequence should you proceed?
Secure the vehicle against rolling away, position the car jack, jack up the vehicle, loosen the wheel nuts, remove the wheel nuts
Secure the vehicle against rolling away, position the car jack, loosen the wheel nuts, jack up the vehicle, remove the wheel nuts
Position the car jack, secure the vehicle against rolling away, loosen the wheel nuts, jack up the vehicle, remove the wheel nuts
