#4333 points
You car has a fault and can no longer be driven. What must you be aware of during towing?
During towing
- a towing bar should be used where possible
- the force required to operate the brake pedal is significantly greater if the engine has failed
- the rear fog lights should also be switched on to indicate the towing procedure
