#10573 points
What should you note regarding the trailer coupling, when transporting pedelecs on a rear-mounted carrier system?
In view of the heavy weight of the pedelecs
- the trailer coupling must have a suitable vertical load capacity
- the rear-mounted carrier system must be suitably designed
- the car’s tyre inflation pressure must be adjusted appropriately
